FX3U - MITSUBISHI - Program an actuator
jaseplc
Jun 2015
Amsterdan
Hello
I am new on mitsubishi cpu plc programming.
I need help regarding the programmation of an actuator.
In fact, the actuator move between two limit switch s you can see in the picture : actuator
I am actually trying to write the program code in GXWorks 2 of the FX3U-CPU of Mitsubishi.
in the attachment you can see what I have started to write and how i have declared my different variables.
I want you to help me make my program work correctly.
I have to count the number of cycle when the system is used in automatic mode. And I have to avoid anyone except those with the required password to be able to reset this count. And I want this count to show up every time the system is used in automatic mode. So I have a little hmi panel.
to the count, I have to consider that: 1 CYCLE = PosFWD + PosREV so that the actuator goes from END_REV_SW until reach END_FWD_SW and then directly come back to END_REV_SW and so on ....
Each mode either AUTO MODE or manual mode CAN BE RESET BY PRESSING RESET on the HMI.
I have not program the RESET for the moment, because I dont really have idea, and due to the fact that my program is not even working at this moment. So I need helps
AND TO RESET THE CYCLE or number of count of the counter, the right password in the HMI.
IN AUTO MODE I have to give the possibility to ADJUST THE TIME THE OPERATOR WANT THE ACTUATOR TO MOVE FORWARD AND BACKWARD INDEPENDENTLY BEFORE REACHING THE LIMIT SWITCH.
BUT IF THE TIME IS TOO LONG I HAVE TO STOP THE ACTUATOR TO AVOID ANY PROBLEMS
IF YOU CAN TAKE A LOOK AT MY CODE SHOWN IN PICTURES BELOWS AND GIVE ME ANY PROPOSITION YOU COULD HAVE OR MAKE THE CORRECTION OF MY CORRECT MY PROGRAM.
THANKS
GXWorks_Variables.jpg GXWorks_code1_41.jpg GXWorks_code2_4.jpg GXWorks_code3_4.jpg GXWorks_code4_4.jpg
I have created the following program in gxworks2. I don't understand why it won't read in the analog value. Sometimes it displays the value but...
1,860
Bonjour, Je n'ai pas de communication modbus RTU vis la configuration ci-dessus. J'ai essayé les deux mode ch1 et ch2 mais rien ne fonctionne...
172
Hello everyone; I have Mitsubishi PLC FX3U 32M in hydropower plant governor, an error message popped up when a technician was working on an...
382
hmi keeps saying "insufficient sensor failed" after the machine runs for 60 seconds. its a fx3u-48m PLC. The plc is not giving any errors or...
2,277
Hello All, I have been trolling through the Proface documentation to find an answer, but I read conflicting information. We have a...
3,938
