ge fanuc 90-30
Aug 2020
eg
hello
I have plc ge fanuc cpu 90-30 connected to scada system indusoft OVER ethernet network .
i want to install another plc cpu 90-30 in same netowrk.
my question is :-
is possible to use digital input from plc to another to use it in the ladder program and how ?
thanks
I would think it is possible, to use it via the network there is two possibilities.
1. Set up communications between the two PLC's some form of messaging (sorry I do not know GE but someone here will), and send the bits from one PLC to the other in some form of message. The other way would be to read the bits from one PLC into the Scada and map them to the other PLC, again, I have no experience with either plc or Scada but I know this can be done on other PLC platforms with ease. In fact I have done this a number of times even with different makes of PLC's even if they would not talk via a direct connection, using two communication drivers on the Scada and mapping the variables from one to the other.
thank you
i want to think first about direct communication from plc to plc to how define the digital input from another plc
if the above not possible i will use scada but i'm not preferred this option due to the scada may be hang or pc s/d and will effect the process
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
46
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
132
I want to buy this program if anyone has it. Absolutely no one has it officially for sale. My cpu is IC610CPU104B My mail...
122
I've got a Micrologix 1100 with ethernet and I'm trying to configure communications to a Fanuc R30iB controller. I'm pretty sure you have to set...
115
We recently purchased a IC693CPU352 module and it appears the internal time clock is static. I can set the time and date but once set it does not...
185
