GE Fanuc adding decimal values to constant problem
treefort
Apr 2012
British Columbia
25
There is a compare block being used 1100 times to compare variables to a constant value -999. The problem is that the GE is changing the -999 to -999.000128 and the compare block is not working. This used to work. We can't get the turbine going because of this.
Anyone have any ideas?
Much appreciated,
Edit: We've tried the compare logic with a test bench PLC and brand new program. Once downloaded, -999 changes to -999.000128
Don't use absolute compares with floating point values, ever.
Use only relative compares (Greater than, Greater than or equal to, Less than, Less than or equal to).
Normally a simple whole number like that can be represented properly in most floating point formats, but don't count on it. Even with the IEEE standards, there are lots of places for slight differences, and platform specific optimizations.
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
47
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
133
I want to buy this program if anyone has it. Absolutely no one has it officially for sale. My cpu is IC610CPU104B My mail...
123
I've got a Micrologix 1100 with ethernet and I'm trying to configure communications to a Fanuc R30iB controller. I'm pretty sure you have to set...
118
We recently purchased a IC693CPU352 module and it appears the internal time clock is static. I can set the time and date but once set it does not...
190
