GE Fanuc DeviceNet Master used as a Slave
Dave Powers
Oct 2003
Vermont
22
I am trying to use a GE Fanuc IC695DNM200 Master module as a Slave to a DeviceNet LAN. The module datasheet says that this can be done, but I am not sure if it can be done with anything other than another GE Master. Any tips on how to configure this module in Proficy ME v5.8? Thanks
Figured it out. I needed to Open the Network Settings for the IC695DNM200 Module, then go to the Connection 1 tab, than change the Connection to POLLED and set the Input & Output Resources to the number of bytes that the module was going to Produce/Consume. Sounds easy now.
The station is very simple. One robot and one group of I/O. The robot is the master on the Devicenet bus, with just a connection to the...
12,522
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
47
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
133
I want to buy this program if anyone has it. Absolutely no one has it officially for sale. My cpu is IC610CPU104B My mail...
123
I've got a Micrologix 1100 with ethernet and I'm trying to configure communications to a Fanuc R30iB controller. I'm pretty sure you have to set...
118
