GE IP CPE305 change IP address without serial cable
Ozpeter
Aug 2014
Virginia
124
So I am happily communicating with my CPE305 at its default, out of the box IP Address of 192.168.0.100. So now I want to download a new project with a different IP Address and I do not have a serial cable.
Normally I would edit the project with the new IP address, set a temporary IP address on the CPU to match then go online and do a download.
However the CPE305 does not support setting a temporary IP address, and I can't think of any steps I can take inside of ME to get around this limitation.
Is this possible or do I need to shell out for a serial cable?
Change the IP address in hardware configuration and download the configuration to the PLC while the target IP address in Machine Edition is still 192.168.0.100. Once the PLC's configuration is changed you will lose communications. Then change the target IP address in Machine Edition to the one you just downloaded and go back online.
If you are connected, you can set the new IP in the CPU's hardware config and download the new configuration at the same time as the new program. Just remember that you will need to adjust the Target IP of Proficy after to re-connect.
I have a Project with multiple small sites that have pipeline valves. The client took the PLC from one site, and wants me to configure it for...
1,475
Hello all, First time poster, long time viewer of these forums. Could not find my solution on here. We have had issues with a Comm Fail on an...
439
GE RX3i CPE305 serial port configured as "RTU Slave", trying to find address info Hi guys, I'm working on a system with a GE CPE305 and the...
2,638
I know Once again I may be sailing in Uncharted Waters but thought I would throw it out there anyway. I have a Emotron TSA52-450 Soft Start with...
5,628
Hi Does anyone know if the IC695CPE305 plc supports writing to holding registers (%R in GE world) using the modbus tcp protocol. I am reading...
2,111
