gx developer help
controlboy
Jul 2007
northampton
Hi
Could any one explain in simple terms how to use Set and Reset coils Do they have a code name, location. I have used them with Dos based Melsec. The GX manual is going to take more time than I have to sort! Why do they Make simple things so hard to under stand, or is it just an age thing?
Many thanks controlboy
I'm not sure about the Dos based Melsec, but in GX Developer, to use the SET and RST you just need to type [SET Y0] at the end of one rung, and [RST Y0] at the end of another rung. Remember you have to use an instruction in the rung, like NC M0 contacts. Any output or instruction at the end of a rung will not work if it is the only thing in the rung.
JOE75140 is correct just be sure to use the square brackets and not the round ones that are for outputs or it will not work.
Thanks Joe
That saved me a lot of work looking through the manual. I've had a break from PLC's of about 6 years so I'm a little rusty. Do you know of a site where I could look at or down load simple programs to get up to speed.
Controlboy
controlboy said:
Thanks Joe
Controlboy
Here and here
edit: not sure they are simple though!
Hello, i want to do a device backup but can´t find it. Someone remembers? :huh:
886
I am attempting to use GX Developer with a Q06 CPU, for the first time. I am attempting to mirror a pre-existing 0-10v analogue output channel...
1,161
Hi everyone, I'm new to ladder programming and I may have been too ambitious thinking I could do a full plc program by myself. My father has a...
62
14,939
Hello everyone, Looking for a little help, I have a simple project but I have not done very much analog with Mitsubishi... Its a Q06HCPU and...
3,495
Hello, i have a problem on my hands and admittedly its my fault. 🙃:banghead: I have GX Developer and GX IEC Developer on my PC i have only...
4,104
