Hardwired Circuit
Try This !
Alternating foot switch
The press brakes I work on also have an auto/manual or jog postion switch.
In auto the press bottoms out to return either by a limit switch or another push of the foot switch. The latter is to allow the metal to relax to it's new deformation.
In manual-jog mode each time the switch is pressed the ram extnds until the switch is released. Repeated pressings of the switch will continue extending the ram.
All done with icecubes.
I don't have a schematic in front of me, but any old press brake should have an example.
I'd check the yellow pages for a sheet metal or metal fab shop in your area with an old Wysong. They may let you look at the schems.
Rod
The (CNC dude)
So I have a sort of unique situation where I'm wanting to run a PF755 from the IO and over ethernet. Of course, this comes with it's own set of...
335
Dear Experts, We have two PLC independent PLC panels with two independent controllers , we need to make hardware splitting for some AI and DI...
1,059
I have a pump house and a tank well over a mile apart. The pump house is hardwired to the tank via direct buried telco cable. Mind you this was...
2,745
Does a hardwired 120 VAC machine need a local disconnect and lock out device? I was always under the impression that it did, but a plant controls...
2,123
Hello PLCs.net! I have a kinetix 5500 drive connected to a gantry, I was wondering if there is a way to do active homing using a PLC tag? At this...
3,124
