Help! DeviceNet for SLC500 Allen Bradley
Buscom
Jul 2013
paris
78
Hello,
Please, I need help for those who have already worked on the DeviceNet protocol with Allen Bradley SLC500.
I am currently working on communication between the SLC500 Allen Bradley and an electronic card. I would like to set the DeviceNet communication protocol between the SLC500 Allen Bradley and an electronic card equip with a DSP from Texas Instruments. The DSP have a serial port. and I have a module CDN066 that make the conversion from DeviceNet to RS232, so that the data can came from the PLC in DeviceNet pass throw the CDN066 and comout in RS232 to go into the electronic card
I want to know if you think it is necessary to program the DSP to receive DeviceNet data or if you think it is not necessary and that the CDN066 by converting DeviceNet to RS232, I am no longer need programming the DSP?
thank you, for your replay,
in fact, my electronic card equip with a DSP from Texas Instruments.
The DSP is a tms320f2812 DSP from Texas instruments. His pin is routed to communicate in RS232 with the electronic card
Based on the information you've provided, my only answer is that you'll have to do all of the DSP programming.
UNLESS you can contact the original designer of the electronic card and find out what they did for programming. A DSP by itself does not come with the programming to do what you are asking.
Hello, I have a device with 68 words input. But one block on the Devicenet Scanner is only 61 words. I am trying to map this device to 2...
549
Machine has existing DN devices that are connected to SLC 5/04. All communication is working fine now. Supplier wants to remove some DN devices...
868
Hello, I am setting up for practice and I am having trouble seeing the 1771 Scanner in RsLinx as well as Rsnetworx My setup: slot 0 : PLC-5/40E...
1,003
Hey everyone, I'm pretty new here, but have been working lightly with AB PLCs for a while now. I've recently hit a stumbling block that I'm hoping...
1,379
I have a 1769 sdn scanner on one panel and a 1769 adn i/o module on another panel, this module got burned and replaced but after replacement...
3,440
