Nova5
I am going to post this in CAPS, feel so strongly about it..
THIS PROGRAM YOU HAVE SHOWN A SNIPPET OF IS SO OBVIOUSLY A CONVERSION, THE TAG NAMES ARE COMPLETELY MEANINGLESS.
If you are now "in charge" of this program, make it your task to put some meaningful tag-names in place of the converted addresses.
Take your time, work out what each "address" does, what it means, and change its name to something that means something, that you, your colleagues, and all yours and their successors will thank you for.
Even if it takes you a month, a year, or whatever, it is worth doing.
Do not mess with tag names until you know what uses them an how.. other PLCs and HMI's will rely on those Names.
At the minimum edit the description of each so it gives the sane information.
