Help for newbie
mbam
Mar 2009
Pompano Beach FL
This is my first exposure to PLC's, do have some electronics and computer background so I'm getting up to speed OK. I know what the different data formats are but have never worked with them.
Using a DL06 (from Automation Direct) with the 6" Micro graphics panel & the thermocouple input card.
Building a control for a parts washer we are updating. Machine has pump, heaters, turntable, fill & rinse valves, skimmer, low water etc.
I have the timers, relay logic and thermocouple set up ok. Display has a analog gauge for the wash temp. Also has a few pages with up/down controls and display to change the set point for the temp control & timers. So here is where I need some direction –
How to scale the thermocouple reading x .1 – also should probably filter it so the heaters don’t get weird. I do know to put a dead-band on the temp control.
How to scale the timer setting & displays to show and increment minutes.
I hope I have this right, the timers are using a V address for the parameter which the up/down & numeric display are hooked to. Does it matter what address I use?
That’s it for now!!
I do plan on using the calendar so we can start the heaters in the morning on Monday’s before we get to work (they take a few hours), but that’s for V2
Thanks,
Marc
Sorry - I wasn't clear. Using the analog meter, so right now it is displaying 799 (it's about 80 deg F here). I don't see a place to set the fraction.
When setting up the 'Numeric Indicator' on the C-More Micro under 'Display Format' on the righ side there is 'Number of Digits'. Set the 'Fractional' number to '1'. Download this to your display. If you are viewing the number from the module using DirectSOFT you won't see a decimal point.
Now I see - I don't have that version on my computer. Will it accept a REAL? Or could you get by without the decimal. You could do a conversion in the PLC and then to the meter from that.
I've used FTView ME for as long as I can remember but am now developing an application with SE. I've imported an ME project that will serve as...
1,487
Just joined the site and wanted to say hello. A lot of googling has sent me to this site multiple times in my quest to learn about PLCs and...
2,873
  • Poll
Micrologix1100 PLC with rslogix software. Does anyone know how to use a single turn absolute rotary encoder as if it were a multiturn encoder...
1,412
Hi all, my first post here, I've been lurking for a while. I'm a beginner and I hit a wall on one of my first projects I'm working on. I know it...
2,569
I am attempting to use GX Developer with a Q06 CPU, for the first time. I am attempting to mirror a pre-existing 0-10v analogue output channel...
1,164
