Help Needed on S5
hagos
Oct 2004
Africa
244
Dear Sparkies,
It'd been long time since I last work on S5 CPU's. So I'd be grateful if some one will help me in this.
We have a 941B CPU , where we came this morning & found it in the STOP mode, WE noticed that the BASP LED lights up. When we recycled the power, the CPU tries to enter the RUN mode, but the RUN LED comes only for a glance where the BASP LED comes on & the CPU goes back to STOP mode.
Any help (as usual) would be appreciated.
Regards
Hagos
Hagos
You will need to interrogate the 'I Stack' to determine what caused the CPU to go into stop mode, the corrective action to take will depend on what caused the stop.
BASP LED comes on to indicate that the digital outputs are disabled and the CPU is in either restart or stop mode....
Paul
I have an old PLC (circa 2007) consisting of Telemecanique/Modicon/Schneider Electric devices. The system has developed errors and unfortunately...
265
Hi I’m after some help , I have a plc program with a baumer verisens vision camera attached I have got the signals working ect but I have an...
977
Hi all, We are facing synching issues with redundancy module, where the Primary is ending up with disqualified secondary. Normally this would...
641
Hi all, I have got this machine that needs to be up and running soon. This machine has Schneider's Controller and I/O modules, 3 vfd's, 2...
925
Is it possible to write to the high speed counter function file "high speed preset" on an AB micro 1100. I have the HSC set up with a MOV...
1,104
