Help needed
Bregan
Aug 2003
i currently need to do a project which consists of using a plc to take temperature readings at different times of the day and storing the read data in the plc for use in the future. i am using Matsu$hita FP2 plcs. a fp2-c1 cpu and a fp2-ad8 A to D input unit. the temperature sensor is a PT100. the programming software used is FPWIN GR. as i do not have even the basic skills for programming the PLC, and the limited time constrains.. i was wondering anyone has the coding avaliable. Or anything similiar to it as a reference for me.. any help is much appreciated.
thanks.
You wrote :
i currently need to do a project which consists of using a plc.... i do not have even the basic skills for programming the PLC...
What about this projects ? Are you a student ? You don't know THIS type of PLC ? Do you know SOME PLC ? Did you read the AD8's manual ?
Did you try to configure the PLC ? Did you wire the sensor ? Did you try to transfer a value from the analog input to the memory ? Did you install the software ? Did you launch it ? Did you create a FP2 project ? Did you have a look on the ON-LINE HELP ? Did you search some kind of usefull function ? Did you call the vendor ? Are you really SURE that your PLC is about to read values "at different times of the day" ? ....
Laurent
I have an old PLC (circa 2007) consisting of Telemecanique/Modicon/Schneider Electric devices. The system has developed errors and unfortunately...
251
Hi I’m after some help , I have a plc program with a baumer verisens vision camera attached I have got the signals working ect but I have an...
970
Hi all, We are facing synching issues with redundancy module, where the Primary is ending up with disqualified secondary. Normally this would...
634
Hi all, I have got this machine that needs to be up and running soon. This machine has Schneider's Controller and I/O modules, 3 vfd's, 2...
920
Is it possible to write to the high speed counter function file "high speed preset" on an AB micro 1100. I have the HSC set up with a MOV...
1,095
