Help with external him for VFD 525
peppin23joe
Mar 2012
riverside
59
HI... I need your help... I have to install a external him for a power flex 525 VFD but I dont know wich one its the better option to buy it..
If you can give me a recommendation about the better external him should be great...
I will like to hear your comments soon...
You have two options, a removable NEMA 1/ IP30 one in a bezel or a one piece 4X/12 IP66. Advantage of removable is easy moving around to clone parameters. Advantages of one piece include lower cost, environmental robustness, and won’t get lost or mixed up.
If in a wet or dusty environment, definitely use the one piece. I would only consider the removable HIM if the drive is located an a clean dry maintenance only area. Easy cloning might not matter much if drives are networked. If the HIM is removed without proper procedure (ALT - Remove - Enter) the drive faults, at least with default settings. This also applies to unplugging the one piece.
Save drive parameters to the HIM for easy drive replacement. If you go with the removable, I suggest taking the time to name the saved files in case HIMs get moved around.
22-HIM-A3 with a 22-HIM-B1 for the removable one
or a 22-HIM-C2S for the sealed one, depending on which one you get you may need a cable either a 22-HIM-H10 (1m) or a 22-HIM-H30 (2.9m)
Alan
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
58
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
22
454
this a program to send data to barcode printer I want to integrate a new printer in a new machine and i wanted to adapt the old prgram on it but I...
171
63
Hi all, hope you are having a great day, I am in need of your help to create a AOI or program that does this kind of job: I have a IO Link...
26
549
