help with VFD on P&ID and HMI
enbeya
Sep 2007
canada
44
Hi guys'
Hopefully all of you are doing well, I tried every where to find standrad symbols to use on P&ID, we have VFD connected to comprossor and have local Pannel and signals using devicenet to DCS or PLC I want to show all alarms and indicators on the Pannel and the ones on the HMI side I ended up having to many XI's and YI's which became more complecated. any opinion will be greatly appriciated guys
Keep it simple, show an HIC or SIC in the DCS connected to the VFD then tell the PLC configurator what he needs to show e.g. speed, current etc. Since you are using Device Net most parameters will be available.
If you are showing a DCS indicator just put the letter H or L beside it to indicate there is an alarm. We use the convention H or L for alarm HH or LL for a trip.
Hope this helps
Roy
Hello everyone, I'm having trouble selecting the right circuit breakers for the "line side" of my VFD. The common advice is to check the...
21
1,447
Hi, I'm assisting a friend with a AT1-04K0X VFD. That's sold under several names like Vikye. Unfortunately VFD's are a weak subject of mine. It's...
387
Hi, I work in a brewery in North Carolina and I need some help finding the output current for a VFD in the PLC. First off I am new to working with...
1,357
Hey everyone, I'm pretty new here, but have been working lightly with AB PLCs for a while now. I've recently hit a stumbling block that I'm hoping...
1,362
I have 3 control panels made by an OEM, they are all identical and have a Siemens S7-1200 PLC with a Siemens CB-1241 Modbus card talking to 2...
4,583
