Help with Vijeo Designer
fullanitox
Jan 2020
Argentina
Hi i developing an aplication with vijeo designer 6.2 for a generic PC. My problem is that i can't add a controller TSX p57 2634m to get variables from it. Only shows me in section of controller Pac Drive - Ethernet: PacDrive Cx00 and PacDrive LMC x00C. Thanks.
Just add a Modbus TCP device
Thanks for reply!. This is an Ethernet device, is the same?. When i add a variable how i adress a variable to a Modbus TCP device?
Yes, in the I/O manager select Schneider Electric Industries SAS > Modbus Slave >Modbus Slave (TCP) then add your equipment, in this case Modbus Equipment
Then set the syntax on the equipment as IEC61131 and use the same syntax as the variables in the PLC so %MW0 etc.
Thanks now i get it.
Hi Guys! i made a project in vijeo designer v6.1. for XBTGT 5230 hmi. this project is not being download on usb disk. and there is no error in...
1,804
Hello I am working on a project that was created in Vijeo 6.1. I only had version 6.0 so I was forced to upgrade. I received my software, but...
6,672
Hi folks! I'm installing Vijeo Designer 5.1 but a window pops out and doesn't let me install it. It says (in Spanish): "El XBTZG935 / USBB cable...
3,598
I need to get the list of Device Addresses & respective Messages in an alarm group but I haven't figured out how to export it. The Alarm Group...
5,083
Hi, I hope someone can help me out. I am using a magelis xbtn-401 as a HMI and a Zelio smart relay to control a solenoid valve. What I am trying...
3,351
