High frequency digital ouput on Siemens S7-300
dfdgdsd
Apr 2007
Home
Hi, I need a 0-1500 Hz digital pulse output from a S7-313C PLC for pulse control of a step motor. What's the best way to handle this? I can't use the regular DOs, as the highest pulse I can output is limited to about 200-500 Hz by the scan time. Thanks in advance.
Looking for suggestions on a pathway for a high speed, variable frequency output for a slitter line. There is a corporate data collection system...
1,694
Hi - off topic but hopefully someone has some experience. I am looking to install a level detection unit for monitoring fill levels in bottles...
1,916
Hi everyone,:cool: I have been facing the problem of encoder (1024 ppr) not reaching to its desired position while in auto mode. The PLC fault...
2,077
I have a problem with an induction furnace heat treatment makes it a car part, it does generate heat through high frequency induction that...
1,505
Hi friends; I use a APU 300 frequency module. Configured as TYPE A counter. The application as under Magnetic pickup signal came into the...
2,030
