Hirschmann RSB20 switch Connection Parameters
bzone
Dec 2021
Indiana
Any idea what that connection parameters are to integrate a Hirschmann RSB20 8 port switch into the I/O tree of Studio 5000?
Have not been able to locate and EDS file online or on the switch itself.
Hi, one will need to add a generic ethernet module and name it for the switch and assign an IP.
I configured a few of those octopus switches when I did a job for GM earlier this year and they weren't in the C.O.
I also had a software tool (Excel) that would configure port assignments, settings and IP configurations into the switch. The processor, ethernet modules and a convenience port setting were all configured into the switch so no need to directly access the switch from the C.O. Hope this helps.
Hi All I have an Ethernet IP MCC application with the option of Hirschmann RS20 switches or Eaton/Cooper 2080E-T. I was wondering how your...
3,441
I have just bought two Hirschmann MS20 and two MM2 - 2FXM3/2TX1 modules but I cannot get a fiber connection between the two. I can connect them...
1,355
Hey guys, Has anyone had any luck / know if it's possible to use Citect to monitor status data and statistics from a hirschmann managed switch...
1,774
hi, We Setup 9 hirschmann MACH1000 switches in an optic ring topology. we have about 30 modicon, ABB and Siemens PLC's connected to this network...
1,754
I have a couple of dell servers and i am trying to use hivision to get opc data display on the FT scada client. I have imported all the required...
1,628
