HMI brightness Is pV + the only choice
gas
Nov 2005
Erie, Pa
531
I have a customer that is using a PV+ with a micro 1500 ONLY to access 2 timers. His machines are used in dirty dark foundries. The AB guy claims that this is the "brightest" screen possible.
This looks to me to be massive overkill and only supports the reps big boat.
How about comments from some of you guys out there.
In 'Dirty Dark Foundries', I'd think even a dim display would be fine. You need a bright display in bright light.
2 Timers? I'd use a panelview micro at the most.
Agreed Tom - I just installed three C-Mores (EA7-S6M). Even for the basic black and white model, the screens are very readable in a bright environment.
Note that this is an STN panel, so viewing angle is more restricted than on the color TFT models. This isn't too much of an issue if the panel is mounted at the right height/angle.
hi there, I'm a beginner pls help when transferring pc to hmi there's an error message on shihlin hmi written com1 station 1: communication...
72
Hello, I have a Mitsubishi FX3G 14M PLC and a E615 HMI from Mitsubishi/Beijer. I'm using GXWorks 2 to do the programming and I have no problem...
149
Good people of PLCs.net, I am currently working with an HMI that is advantech 1250H, that communicates with a 1769 Compact logix and Currently...
79
Hello all, I know its not good practice to have duplicate destructive bits when writing plc code, but I'm wondering about writing to the same tag...
121
Hi All, As a precaution my company has been collecting copies all the HMI and PLC programs. I have recorded copies of most of our sites...
78
