HMI panel recommendation
godfrey
Apr 2002
Charlotte, NC
412
The spec calls for a Quantum PLC and HMI to be programmed with Wonderware. I need to propose a touch screen to do this. Any suggestions?
Something like This? Or This?
If you can at all avoid going with the integrated panel mount computer and display, I'd suggest doing that. If you really want to have a rugged PC mounted near the monitor, go with something fanless and industrial like This.
I have a bunch of the Integrated PanelPC's here, but much prefer splitting the screen and computer. When the backlighting on the screen goes, its much cheaper to just change the screen (or fix it). Replacing the backlight unit on a typical PanelPC is virtually impossible.
I copied a panel in factory talk HMI for an identical system. The label names are still the same as the original panel but I am trying to change...
142
Somebody know how to unlock a pass protected macro in easy buider ?
111
Dear colleagues, hello to everybody! I have a problem with Quickpanel IC754VBI06SFD-GF Proficy Machine Edition Runtime 6.5 QuickPanel View V2.00...
666
Hello, I want to plot a line on X,Y axis with defined start and end points on Quick Panel+. I use PAC Machine Edition 9.7, and it supports...
1,737
349
