HMI Shortcut {::[SLC500]B18:10,L2} 32bit?
ian.smith7
Aug 2002
UK
145
Hi all
I found this Shortcut {::[SLC500]B18:10,L2} in a PV+ pointing to an SLC500. Is it 32 bit looking at B18:10 + 11?
Only 16 bits (B18:10) are used in the PLC & HMI program.
Now for the stupid question. would L3 = 48 bit & L4 = 64 bit?
Cheers
Ian
Okay found this in Document 25342 on Rockwells site.
The L2 value is the array size and can be up to 10 (L10) for 10 consecutive Bit registers but can be bigger for N registers.
Probably the reason I did not recognise it is it only (?) applies to HMI alarms, something I have not dealt with a lot.
ian
You've got it; that's a typical address for a two-Word block of data used for Alarm triggering in a PanelView Plus.
The thing that I always have to get straight is that when you use "Least Significant Bit" (LSB) mode for triggering Alarms, Bit 0 of the Word is Alarm trigger position 1.
I've done a lot of applications for PV+ where the first test showed "hey, the wrong alarm is showing" because I forgot that difference in numbering.
Good people of PLCs.net, I am currently working with an HMI that is advantech 1250H, that communicates with a 1769 Compact logix and Currently...
30
Hello all, I know its not good practice to have duplicate destructive bits when writing plc code, but I'm wondering about writing to the same tag...
99
Hi All, As a precaution my company has been collecting copies all the HMI and PLC programs. I have recorded copies of most of our sites...
63
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
90
150
