Horner XE102 Menu Screen misbehaving
rmb550
Nov 2009
Ontario
86
We have a menu programmed into our XE102, and found when we navigated to it, it was flashing and did not accept input.
By poking around a bit, we found a Register Number over 18000 in the "Enables" box. When we cleared that box the problem went away.
I tried to understand the Help file write up on the Enables box but still do not get it. Can someone clarify what it is?
Also, can someone explain how such a crazy register number ended up in there?
Thanks,
rmb
I have a Horner HE102 with the Ethernet Card. I have set the IP address to 198.168.1.4, and I have set my laptop to 198.168.1.3. I have connected...
2,965
I was loading a program onto an XE1e2 PLC and it got stuck on these two windows and won't progress. It won't let me connect from the PC to reload...
95
I am trying to set up a piece of equipment with a Horner HE-X4R. I'd like to use structured text and so far I'm just trying to get a basic On/off...
96
I am having a problem communicating my PLC with Drive via Modbus connection. I start by opening the port and there is no problem, but then when I...
228
Hello, I’m new to this forum and if I’m posting incorrectly let me know. I’ve been having an issue I can’t seem to figure out. I’m sure it’s...
134
