Horner XL7e
mrjkidd
Aug 2014
Tea, SD
Trying to scale a 4 to 20 signal to read temp. I am using a banner radio gateway using Modbus protocol. I'm using an unsigned integer and when I try to scale it says it must be a signed integer. How am I supposed to scale this?
Not sure what your hardware will produce but you can convert a USINT to a SINT to get the conversion for your logic.
I assume your data coming across looks like something in the range of (0-23767) or similar.
If this is the case it will work.
If the data coming across is in the range of -32767 to +32767 you may have some issues.
Though I think horner uses a 32000 as a limit and anything over is an overflow.
Think I got it. Math functions will let me use this as an unsigned integer. I can divide it in half and then scale it with a min. value of 0 and max value of 32767.
Hello everyone, Currently I am working with a PLC/HMI Horner XL7e over Ethernet/IP communication with an AB ControlLogix, and suddenly the...
1,759
I was loading a program onto an XE1e2 PLC and it got stuck on these two windows and won't progress. It won't let me connect from the PC to reload...
106
I am trying to set up a piece of equipment with a Horner HE-X4R. I'd like to use structured text and so far I'm just trying to get a basic On/off...
109
I am having a problem communicating my PLC with Drive via Modbus connection. I start by opening the port and there is no problem, but then when I...
274
Hello, I’m new to this forum and if I’m posting incorrectly let me know. I’ve been having an issue I can’t seem to figure out. I’m sure it’s...
145
