How to connect Mitsubishi PLC Rs422 to another Rs485 communication device
Huybm
Jun 2016
Ho Chi Minh City
Hi everybody!
Im meet a big problem that my PLC is FX1n 24Mr and he has an Rs422 Com port, and the HMI is Delta TP04P series has Rs485 2w communication port.
I try to connect TX+ with Rx+ in 8 pin PLC them call them are +
Tx- with Rx- then call them are - and next step i connect + with +, - with - on HMI but nothing show it is right, HMI alarm Error Com: 485 still display.
Can i connect directly them, and if the answer is yes that how to do that.
Thanks very much.
Probably not directly. Typically RS422 is a full duplex communications process and RS485 is half duplex. So the problem you are having is that RS422 full duplex transmits on one pair of wires and receives on the other pair where RS485 transmits and receives on the same pair of wires. What you need is a RS422 to RS485 converter however you will also need to confirm that the PLC, even though it’s using RS422, will communicate via half duplex.
Thank for reply. I wonder that my old object, i could connect plc fx2n 32mr with hmi weintek MT6070ip throught rs422 on plc and rs485 of hmi. It had 4w connecttion and it work well.
I bought a fx1n 485 bd and connected that delta hmi. So problem was solve.
Thanks you.
Hi all, Trying to find the best way to connect to a PLC over the internet, I'm in England....PLC is in Ireland and need remote access. How does...
2,545
I WANT TO CONNECT A DELTA TP(PANEL) TO MITSUBISHI PLC MODEL NO FX-128MR .I DONT KNOW ABOUT THE COMMUNICATION CABLE AND CHANES I MUST DO IN PLC AN...
5,092
Help, help... I want to connect a PC installed WinCC Siemens to PLC Mitsubishi MELSEC Series Q3A through communication is Melsecnet 10. Which...
5,221
Hi everybody! I have 2 Mitsubishi Q series PLCs that have built-in IP addresses of 192.168.3.xx and both of them have Ethernet modules...
869
Got a used with warranty Q064UDEH It is not going to have the correct parameters to allow me to Connect the Ethernet and download the program...
408
