How to Interface with 1784-PCMK to SLC 5/01
mapizarro
Apr 2004
Santa Cruz
22
We have a PCMK card and I can interface and communicate to PLC5 processors with no problem.
But, now we need to communicate with a SLC 5/01. we have 1784-PCM4/B cable (PCMK card to RJ plug), but I do not know what drive I need and how to configure the drive to talk to this old processor.
The laptop have win98 operating system. Thank you for your help.
In RSLink under configure drivers change network from DH+ to DH-485.
Set station number to something different then your SLC5/01.
See Pic below:
Slc5/01 & desktop
I'd really appreciate if any of you guys out there could help me.
I have a SLC5/01 plc. I want get myself into plc programming but do not know how to start.
Again, All I have is the plc, my desktop and access to the software. I was looking out in the web and it seems that I need some expensive cables and adapters to have those two guys talking huh!. What exactly do I need?
Thanks for your help.
HP
The 1747-UIC is probably your safest bet:
http://literature.rockwellautomation.com/idc/groups/literature/documents/pp/1747-pp017_-en-e.pdf
http://raise.rockwellautomation.com...ents.asp?CID=549E8D1292874EEAAEBE03AEE2D9A745
If you are running windows XP SP2 or earlier and plan never to upgrade to SP3...then you may be able to use a 1747-PIC:
http://raise.rockwellautomation.com...ents.asp?CID=4C9C780AC8C94BDA87985C0A2408BCFE
The PIC may be cheaper on ebay since it is quickly becoming useless with newer operating systems...
The other alternative is the 1784-PCMK (laptop PCMCIA slot) or 1784-PKTx (Desktop PC PCI slot). This option is the most expensive, and then there are cables to add to that cost.
Paul
another way to think about is to upgrade the processor to at least an SLC-5/03 ... that lets you program through your computer's serial port (or an adapter) with just a plain old null modem cable (around $10) ...
if you shop on ebay you might find a deal on an SLC-5/03 (or better) for around the same cost of "cabling-up" your existing SLC-5/01 ... expect more horsepower - and less headaches too ...
and welcome to the forum ...
I've got a CLX system with a controlnet network. I need to pull some tag values out of the PLC, crunch some numbers with a proprietary piece of...
4,089
Hey guys, I just wanted to see if any of the bright minds on here had any opinions on these relay interface modules. Particularly, I would love to...
48
Hello world! The company I started working for has these valves that they ordered years ago as spares. now we have to add couple valves on...
203
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
901
Does anyone know why the connection interface is greyed out and says why I can only use Teleservice instead of the other options like PN/IE? I am...
238
