TIA Portal Connection Interface
integration
Feb 2024
Australia
Does anyone know why the connection interface is greyed out and says why I can only use Teleservice instead of the other options like PN/IE? I am not directly plugged into the PLC, I am trying to access it through a remote computer on the same network as the PLC. I can ping the PLC but I can't access it. I am using TIA Portal V17
Any ideas?
Perhaps LLDP is switched off in your Ethernet adapter settings, or tia does not recognize your Ethernet adapter. This also happens to me when my Ethernet cable is not attached.
I tend to sleep my laptop quite often and have found that sometimes interfaces in TIA Portal disappear on a wake-up, a restart of the laptop is the only method I have found so far to get them back again.
What does your Control Panel, Siemens Communication Settings show?
I agree about interfaces sometimes being gone after sleep mode. It also seems to be related to if the ethernet interface didn't exist when *some event* happens (not connected to VPN yet, USB not plugged in, etc), Portal doesn't see it until a reboot.
Hello gentlemen, Im working on a small project on TIA Portal, about establishing a Modbus TCP connection between my ET200SP plc and a socomec...
310
Hi, I want to use PLCSIM because the hardware I was working on has now been delivered to customer. Which option do I choose from this drop-down...
368
How can make communicate between wincc scada tia v13 and modicon plc m258 without using opc server i found in tia portal v13 for wincc (...
1,434
Siemens question: If communication between HMI and PLC fails, how can I detect that in the HMI for multiple connections? Thanks Pavol
5,731
Hello all, I am hoping someone can help me with an issue I am having with a HMI. I am trying to update a HMI using TIA prtal versions 13 and 14...
5,622
