Humidity / Temperature Control
mjamil
Apr 2002
PK
162
We are looking to develop & Install an environment controlling system. A suitable system may consist of the following 3 sub-units.
1) HUMIDIFYING UNIT, to add moisure during the winter (dry season).
2) DE-HUMIDIFER UNIT, to remove excess moisture from air during the rainy season.
3) AIR COOLING / AIR CONDITIONING UNIT, to maintain the Temperature.
4*) It would be worthwhile to inlcude the Air cleaning filter at this stage.
I am interested to know what kind of issues we could be facing, assistance in the selection of equipment.
and ofcourse the difficult part, inter-linking of the DE-Humidifier and Huidifier units, so that both of these dont turn on at the same time, it gets more tricky if more INPUTS (sensors) are used.
Comments and directions (links) are welcome.
There are lots of RH sensors on the market with analog outputs, tie this into a small PLC. I would guess that if the corret sensor is selected, you could also get the temperature from the same unit, (can't help with the selection, I've never used one). Use compares and have a small deadband.
Example: Desired RH=60
When RH=61 turn on dehumidifier until RH=60
When Rh=59 turn on humidifier until RH=60
This will give you an effective deadband of +/- 1, you can decrease the deadband if desired.
You could do something similar with the temperature, many of the programmable heat controls for the home allow deadband adjustment, you may or may not want to include this feature.
If you select a plc with a real time clock, you could also include features to change the setpoint based on time of day, or day of week. This could be used to conserve energy when the space is unoccupied, such as nights and / or weekends.
I suggest a small user interface also, this would allow setpoint changes, filter status, etc...
Ken
I am looking for temperature/humidity sensor recommendations. Would like the sensor to display temp and humidity. Need to connect to a Contrologix...
232
Does anyone know of a sensor/transmitter that is able measure humidity/dewpoint/water concentration in a stream of 1200F air?
3,430
Hello, Has anyone developed the relative humidity value by a temperature thermocouple? I also have pressure values. I have seen some formulas to...
1,973
Greetings, I've done some basic web searching and haven't been able to find what I'm looking for. I'm looking for a basic Temperature/Humidity...
10,181
They will both be measuring ambient temperature and humidity. I will need to take the inputs into an 1769-L32. I have both rtd and analog...
1,782
