IC693BEM341 FIP Bus Controller
calum stewart
Dec 2019
Toowoomba
Hi All,
looking to see if anyone has a copy of either GE-Fanuc or Alspa FBCLOAD utility.
we are trying to retrieve the configuration from a FIP Bus controller that is in production, no known backups of the configuration or software.
we have the 90-30/80-35 CPU config backed up and the logic program although the descriptions are stripped.
Any assistance from your old software libraries welcomed.đź“š
Hi I need to connect to a WorldFip network. Does anyone Know of protocol converter or a current PLC that works with WorldFip thanks
2,530
I have been using Alspa PLCs (C80–35) and fip controller (bem340, bem330) modules I have problem that, a bem330 (remote I/O scanner ) has been...
2,854
I'm trying to configure an Alstom FIP controller Module BEM340. The PlC is an Alstom Alspa C80-35, which is based on the GE-Fanuc Series 90-30...
3,509
We have an opportunity to look at a plant upgrade, however the fieldbus protocol in use at the plant (which they'd like to retain) is FIP (Factory...
3,612
Hi, Has anyone any ideas how to get FIP IO (field interbus protocol) (remote blocks made by telemecanique) into a control logix system. Regards...
2,568
