Idec FA2J
nazamandy2
Jun 2011
Bulacan
Is it possible to use PFA-1U51 instead of PF2-CLA for an FA2J CPU? (PFA-1U51 is Computer Link Interfafce Unit for FA1J Idec PLC)Anyone?? Please!!!
The PFA-1U51 works OK with FA-2J
I think you need cable PFA-1A51 to connect to the PLC, or PFA-1A11 to connect to the program loader. The cable to the PC is PFA-1A54, but I think I made my own (haven't used IDEC for nearly 20 years).
I have the CPU FA2J, the problem is sometimes the clock scan of 1 sec is extended to 5 sec, causing fault in the process, the plc have connect to...
1,961
Apologies for not being the best IDEC programmer. I recently was doing some inspections on a site that had 3 FC6A IDEC processors. The issue is...
111
I'm trying to establish communication between an HMI DELTA (DOP-B07E515) and a PLC IDEC (FC6A-D16R1CEE) via the RS-232C/485 module (FC6A-SIF-52)...
585
Has anyone interfaced a PLC with a Control Techniques drive Nidec 750 using Modbus TCP? I am attempting to do so using an Automation Direct...
907
I'm involved in upgrading an IDEC FC5A-D12S1E PLC to a FC6A-D32P3CEE. I've attached the original layout of the system. Since then, another HG3G...
449
