idec & freewave fgr2
kf5aeo
Dec 2013
big spring
ok a customer we have has multiple tank batteries with pumps but so far only want to monitor one of those batteries tank levels. we have idec fc5a-c24r2 and c24r2c plcs in just about every battery. would it be better to add Ethernet moduals to the plcs, and use Ethernet radios, or just tie serial radios to the pls and use an Ethernet ready plc at the master location to send out the alarms?
Also has anyone used the idec and freewave combination?
I havent used Idec but have used many freewaves. they are a great solid serial radio. If you are just collecting data, the serial radios will work just fine. If your customer requires the ability to remotely connect to the plc or other ethernet devices then look at the ethernet radios. otherwise the serial will work fine.
I'd just use the serial too. Using some IDEC's now too. Serial to our remote batteries, then Ethernet to SCADA from master
Awsome. Thats how i figured id end up doing it. Id like ethernet to make it easier to do troubleshooting, but ive read you can only have one "slave" using ethernet.
Not sure but I'll try to study it some this week. I would suppose the modbus/tcp wouldn't care about a slave. o_O
I do know the tagging form the Master is replicated in the slaves much like the produced/consumed tagging in allen-bradley processors. Pretty slick and very reasonable too.
ok so I have everything programmed and all comms settings the same was told you have to cross the tx from plc to rx on radio on both sides is that right?
Apologies for not being the best IDEC programmer. I recently was doing some inspections on a site that had 3 FC6A IDEC processors. The issue is...
115
I'm trying to establish communication between an HMI DELTA (DOP-B07E515) and a PLC IDEC (FC6A-D16R1CEE) via the RS-232C/485 module (FC6A-SIF-52)...
598
Has anyone interfaced a PLC with a Control Techniques drive Nidec 750 using Modbus TCP? I am attempting to do so using an Automation Direct...
910
I'm involved in upgrading an IDEC FC5A-D12S1E PLC to a FC6A-D32P3CEE. I've attached the original layout of the system. Since then, another HG3G...
453
Hallo all, We are servicing machine automation using PLC Idec FA 2J. I'm trying looking for the PLC user manual, but till now didn't get at all...
797
