IFIX SCADA and uPLCs
Frelecing
Oct 2010
Uruguay
73
Hello everyone:
I need your opinion with this:
I have a production line that's controlled by 2 AllenBradley PLCs 5/20, and was installed like 12years ago.
There is also a SCADA implemented with CIMPLICITY that supervises this process, but very very soon will be changed to IFIX 5.0 (we are in the process of testing the new SCADA)
Many changes have been made to the line in these 12 years, and some of them are not included in the PLCs control logic, they are manualy activated, and they are not "seen" with the SCADA.
Now we want to automate this proceses. And for example in one case, we have to control a loop between 2 devices: a mill and an electromagnetic vibrator that feeds the mill.
I like the idea of including this process in the original PLC since we have some free analog I/O in it. But the other engineer who's working with me, and has been in this company for much longer (I've been here for only 4 months, and it's my first job! ( so I have to respect his opinion )) wants to use uPLCs (I call Crouzet Milleniums, Telemecanique Zelios, Siemens LOGOS, etc, uPLCs) in this local loops, because of wiring problems, etc... And then, connect them with the main PLCs, and SCADA Pcs, via ethernet.
My question is if it is possible to do this with Zelios or Crouzet Milleniums with IFIX SCADA, I mean, does IFIX provides drivers for this devices, or it simply doesn't need them? And how hard can it be to impement a network like this?
I'm sorry if my doubt seems a little dumb, but I've never even seen a PLC network, and this is my first aproach to SCADA. As I said earlier, this is my first job as an engineer!!!
Thanks, I am learning a lot in this forum. it's only that questions keep coming to my mind!
If I understand you, I agree with you, a couple of reasons.
A. What you refer to as a uPLC most think of as programmable relays and not very good at either analog or networking.
B. Adding hardware adds 'point of failures' to the process.
C. You could do this with iFix and Ethernet I/O but then you have added 2 points of failure to the process.
Hi everyone. Ifix scada is new for me. Please help help me to clarify is it possible to open Ifix scada runtime on dual monitor and how to do? Thanks
461
I have a client that has iFix 5.8 installed with a Primary and secondary node. They have two terminal servers that they use for their thin...
2,223
Hi! I am using ifix first time and looking backup scada to learn things. For Datalink I am using following tag reference and it is working fine...
2,425
Hi guys. I'm trying to make visualisation in iFIX5.1 to my project where I use S7-1200 with TIA Portal. I am using PLCSIM with Nettoplcsim to make...
3,077
So, I'm very new to PLC and HMI's and I was asked to investigate something that occurred with my client's system: They set up a queue list of...
1,556
