iFix: Using .NET DatePicker to Modify Window Variables
MoraleC2
Jan 2016
East Coast
23
I am building a report screen with a SQL table display, and I want to be able to adjust the time range from which data are pulled (something I could do in my sleep if I were working with Ignition). I figured the easiest way for the operators would be to use a DatePicker object from .NET. So I made window variables for start and end date (strings), which are used to build the SQL query, and animated the Text property of the DatePickers to those variables.
However, when I choose a new date through the DatePicker, it does not update the associated variable. It's a similar problem to what I encountered when trying to control a variable with a ComboBox, but that was solved with an event script. The DatePicker is not as straightforward; there's no "OnDateChange" method or anything for me to invoke, as far as I know.
Can anyone give advice on how to properly link a .NET object with a window variable in iFix? I must be missing something.
Edit: Nevermind; the CalendarClosed event can be used to assign the new text value to the window variable. Problem solved.
Hi all, I have an iFix SCADA that is currently comunicating to 2 Toshiba T2 PLCs using Serial. However the system has grown and now I'm looking...
3,513
Hello! Currently getting ready to vet a rather large studio5000 program change with Ifix addition and the thought occurred to me that it may be...
4,238
Hi all Can any one tell me on how to communicate bristol control wave plc to ifix using opc drivers in ifix...pls...its in critical stage...
2,304
i use ifix communicates with siemens plc through si7,when the picture was opened in ifix,it shows the communication was disconnected and can't...
3,356
I dont see any option in database manager all i see how i could show those in alarm summary ?? :) also would be great if i could configure the...
17
7,547
