IFM 3d OD200 Camera
Nova5
May 2013
Northern Snowball
566
Anyone delt with this little orange beasties? I have one giving me some weird information..
My normal display is a nice skijump looking ramp. Then often enough I get a strange sweeping shadow from one corner of the image that changes my minimum measured distance from 2300mm to 400mm. Nothing is in that 400mm range, I've stood on the catwalk near the camera and there isn't squat there when its happening, no movement at all in any way. yet it sweeps in/out for a bit then is gone, comes back, goes away, on and on. its gone much longer than its there. I don't feel any air movement, there are no moving objects, no sweeping light sources...
FOund the problem.. close inspection needed.. Spiderweb in close proximity. it would wave in and out as a transparent line through the camera's vision. camera reported the closest object at 15" away. spiderweb was only a few inches away causing the disruption.
Hi Everybody, I Have an issue with IFM 02d224 camera. the camera communicate with contrologix PLC by ethernet. there are two applications in the...
78
Hello, I am new to Codesys, and am trying to learn about it for a project we're developing. I've got a couple questions, but first a little...
176
How can I integrate my S7-300 Simatic with the IFM AS-i Master AC1335 and its slave IOs, such as 2411 and Airbox 2041, into Simatic Manager?
130
When adding an IFM AL1322 IO-Link Master Module to a 1756-EN2T Ethernet Card on a 1756-L82E Controller, The Input and Output data file does not...
111
Hello, I have downloaded the IFM AL1327 .eds file and went through the EDS Hardware Installation process on Studio 5000 v32. It seems to work...
1,069
