spacecoolaid Member S Join Date Dec 2023 Location michigan Posts 1 Dec 4, 2023 #1 Hello, using Ignition I want to automatically change the time zone for 30 Allen Bradley plc's at the same time, is there an efficient way to do that or even a way through Ignition gateway?
OkiePC Lifetime Supporting Member Join Date Mar 2005 Location ENE of Nowhere Oklahoma Posts 11,804 Dec 5, 2023 #2 Go here: https://compatibility.rockwellautomation.com/Pages/home.aspx In the search bar, enter "Logix5000 Clock Update Tool" That software will allow you to pick controllers and schedule times to update their clocks based on the time zone of the PC on which it is running.
the_msp Lifetime Supporting Member Join Date May 2008 Location Northern Ireland Posts 1,271 Dec 6, 2023 #3 Can you do it from Ignition? Yes: https://forum.inductiveautomation.com/t/syncing-gateway-clock-to-plc-clock/12279 Should you? That's your call.
