Panel PC / Ignition Opinions
I believe it's stored in the edge gateway internal historian. I have never installed a SQL server on an Edge gateway.
The edge app can be modified using any machine, as long as it's connected to that box - the same way that I can launch the designer on any machine as long as it's connected to any other Ignition server that contains the project I want to edit.
There are gateway administration modules that again, I've not used, but I think it can manage things like backups of edge nodes.
I've only ever used Perspective for edge panels, because that's what I use across the board now, but I believe you can use Vision if you prefer. From what I gather it's an either/or - you either develop in Vision and get 1x local client and 1x remote client, or you develop in Perspective and get a two-session license.
Thanks! That helps alot.
Lastly is the edge designer environment the same as Vision? Or is there yet another variation to learn.
It's pretty different. I had some experience with Vision and when I first went to mess around with Perspective it was definitely an adjustment.
Inductive University has a nice Elective course where they walk you through designing and building a simulator program in Perspective that walks you through a lot of the features and tools to help you understand.
Yeah I'm familiar with Perspective also. Is Edge development only Perspective?
I think it's been about a year and a half since Inductive Automation started offering the Vision "panel" edition for free for small, single PC...
3,259
Is there anyone who can help me regarding this HMI is missing the choices when I make a new Device in TIA. Only 7" Display above are the choices...
81
I have a German programed ME program. I want to know what tag in the PLC a latched button turns on. However when I open up the tag properties I...
207
We are considering dropping our UL membership because most of our customers do not care if we are a 508A shop. However, there may be times when a...
397
Hello, I need to create an automatic transfer panel that connects to the generator when the mains power is cut. I can draw up to 60kW and draw up...
87
