Panel PC / Ignition Opinions
I believe it's stored in the edge gateway internal historian. I have never installed a SQL server on an Edge gateway.
The edge app can be modified using any machine, as long as it's connected to that box - the same way that I can launch the designer on any machine as long as it's connected to any other Ignition server that contains the project I want to edit.
There are gateway administration modules that again, I've not used, but I think it can manage things like backups of edge nodes.
I've only ever used Perspective for edge panels, because that's what I use across the board now, but I believe you can use Vision if you prefer. From what I gather it's an either/or - you either develop in Vision and get 1x local client and 1x remote client, or you develop in Perspective and get a two-session license.
Thanks! That helps alot.
Lastly is the edge designer environment the same as Vision? Or is there yet another variation to learn.
It's pretty different. I had some experience with Vision and when I first went to mess around with Perspective it was definitely an adjustment.
Inductive University has a nice Elective course where they walk you through designing and building a simulator program in Perspective that walks you through a lot of the features and tools to help you understand.
Yeah I'm familiar with Perspective also. Is Edge development only Perspective?
I think it's been about a year and a half since Inductive Automation started offering the Vision "panel" edition for free for small, single PC...
3,277
Background for the question: A service man from a sub-supplier has made changes onsite to a Siemens PLC and HMI program. He has not made a backup...
41
Hello, I am a plc engineer and I have a job to do in the NIGERIA 25000 TON GRAIN SILOS STORAGE CONTROL PANEL. A problem where the panel is not...
74
We have boiler control system runs on A-B PLC. The interface is A-B Panel View Plus 7, mounted on the local control panel very near the boiler...
68
Can I connect two A-B Panel View 7 to a A-B PLC. Same graphics etc. One on the local control panel and the other Panel View 7 in a remote control...
59
