Ignition & RsLogix5000 AOI question
ohnedich6
Jun 2014
Midlands SC
67
I've got a question for those of you with Ignition experience:
I've been interested in Ignition for a few years now, have not had a chance to use it unfortunately, and was wondering about how RsLogix5000 AOI's local tags (strings in particular) work with Ignition. I know if you set a local tag to "Read/Write" in the AOI then in FTView ME/SE you can use said tag (even though it will not show up under the tag browser). Is this true with Ignition or is this local AOI tag feature only allowable on an FTView ME/SE system?
Thanks all.
-Nathan
ANYTHING should be able to access a Read/Write enabled Local AOI string tag. I've done it with Intouch / System Platform for example.
Strings can be tricky things for communication drivers to handle, however. They often aren't very good at interpreting the .LEN to trim the \$0\$0 blanks of the text within the string tag.
Hi, I have questions. I have Analog Input that need to put into Ignition Designer. But I don't know how to put?
119
Hey guys. We've been learning Ignition and going through all the courses on Inductive University. I really like the software and the things you...
20
1,157
Hardware: 5069-L320ERMS2 Software: Logix Designer 35.11 / Ignition 8.1 Issue: When attempting to write to the tag "HMI_DRV200_DynamicTrim" in...
771
Hi all, happy new year! I read a topic lately and many more before that where a lot of people saying that Ignition is damn good SCADA, so I...
340
Hello, using Ignition I want to automatically change the time zone for 30 Allen Bradley plc's at the same time, is there an efficient way to do...
460
