IGS tags in demo mode
syedadnanmoin
Dec 2018
banglore
hi,
i am facing an issue over the IGS tags communication in demo mode.
just i need to clarify that number of tags i can use in demo mode?
if not limited then why all the tags are not working continuously at a time.
(tags were working alternatively)
any suggestions or solution will be helpfull.
There is no tag limit and the demo should run for 2 hours at a time. If you are alternating between good and bad quality then you are probably polling the device too fast. You should see some type of error message being posted in the IGS Server event log.
Hi. I'm trying to update the firmware on some ControlLogix's. They're being polled by an IGS driver. After the upgrade, my floats and integers...
1,425
We have many sites with PLC-5s and 1785-ENET sidecars that are being pounded pretty hard by the GE IGS driver (Kepware) and iFIX/Historian...
1,003
Hello, I am converting to iFIX 6.1 and talking to a PLC5. I have several TX tags that were looking at N32 addresses in the PLC5 and were getting...
2,969
Hello, I'm looking to setup a test rig in the workshop for testing the likes of the following units; Elau MC-4 Servo Drives & Pac Drives...
1,791
Hi, I've got a ML 1200 C series with only 1 port and would like to connect to our DCS via Modbus. Since there's only one port, I've decided to...
1,499
