Input Conections
jm barboza
Sep 2005
Monterrey
Can i to connect in paralell an analog input from a transmitter at the same time in a channel of PLC and in a channel of a process register ?. The configuration in the channels of PLC are single ended (PLC 5/15 and Yokogawa video register)
Thanks a lot
Greetings jm barboza,
Thanks a lot
When I hear the word "Transmitter", I always assume its output is mA not volt, anyway the guys before me already answered your question .. If you need more details, Visit This link
"Single ended" implies 4-20 mA, so you can't run parallel, but you may be able to run in series. As mentioned above total resistance capability of the transmitter needs to be checked. More likely, though, is the possibility of ground loops causing you problems. The PLC input card may have "-" tied to common. If the Yokagawa does the same, then you can't run them in series - only the fisrst unit will get the signal. If the Yokagawa input channel is islolated you can run them in series, but the Yokagawa must be first in the loop.
Hello All, After trying to transfer some field changes on the safety scanner microscan3, and verifying, the device is stuck at .... waiting for...
63
I have a 120V relay, 120V DI card and a analog input. I was wanting to know if i could put a 24V DI and well as a 120V DI card on the same plc...
89
Hello, I'm looking for a dirt cheap digital display + input, that would be wired to an analog input and analog output. This would be for my home...
266
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
93
All, I have a PowerFlex 525 driving an agitator motor. The goal is to have the agitator start automatically after a power loss or a comm loss. I...
96
