InTouch Auto Hide Window when clicking off of it?
abishur
May 2012
Texas
47
Does anyone know of a way to automatically hide a window (pop-up lets say) when you click off of it?
I couldn't find a way to make a true drop down list so I'm spoofing one by creating a static window to pop up when I click on a down arrow image. I would like it to automatically close the static window if the user clicks outside the drop down box.
I could use the $ObjHor and $ObjVer to automatically close the window whenever the mouse strays outside the window, but I would get annoyed by that after about the third time I accidentally moved the mouse outside the window before I had clicked on the screen name I wanted to navigate to.
If there was a key function for monitoring left mouse click then I could take the current $ObjHor and $ObjVer and write them to a memory integer then use those memory ints to close the window. But I can't find a way to run a script on mouse click.
Does anyone know a way to accomplish this?
I know this doesn't help much, but there definitely is. I used to do that years ago... Seems like it might have been a script or event that would fire if the screen was NOT clicked within a defined bounding box (my autohide window).
Hey all, trying to automatically log on a user when my InTouch application starts up, I'm not the best at InTouch scripting so I'm looking for...
3,359
B
In InTouch (7.0 / 7.1) you normally use the Application Manager to select which InTouch Application is used by Draw / View. I need to select...
8,160
I have a problem, I'm running an AE Licence Manager on a Windows 2016 Server, and my Window Maker is on another separate Windows 2016 Server. My...
54
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
145
Trying to export a Modern application for an upgrade to Intouch 2020 but I cannot export the application from the 2014 version because the export...
137
