Inverter Connection via Profibus
cousteau
Aug 2008
Thessaloniki
I have a Siemens Simatic PLC 314C-2DP and I want to communicate this with two servo-inverters (LTi Drives) independently via Profibus connection. I have already used a routine (FC) that calls the appropiate System Functions of Step7 (SFC13, SFC14, SFC15) but unfortunately the servos moves with the same speed, same direction and same positioning as I have only one servo. If someone knows how can I solve this problem, please post me soon. Please note that is my first time that I use Profibus for such of this communication. Thank you in advance.
Hello Cousteau;
This should only happen if somehow the same addresses were attributed to the servos, which the configuration software should pickup and reject.
Maybe you could show us a screencapture of your Profibus configuration, and of your control blocks for each servo? We might be able to formulate different ideas we could test.
Hope this helps,
Daniel Chartier
Good Morning, I got an IMO HD2 inverter with 2 slots and on the first slot I put the ethernet module (HD2-E-ENET) and the second one is free...
1,283
Getting back into the controls field after a long hiatus going to school. Due to unforeseen circumstances I have been suddenly placed into...
3,213
Hi all! I am a noobie to the electronics world trying to learn as many as possible.Recently the company I work for asked me to present with...
7,445
Hi folk, I would like to know what kind of Parameters should I setup for controlling with Profibus. My old Lenze 8200 motec 0.25kW have a busted...
93
Hi; In a cabinet of a machine, a Fatek PLC with an Ethernet communication card is working. In the same cabinet, there is a 1 kW inverter. When...
549
