Is ML1200 output sinking or sourcing?
Preeya
Nov 2003
112
I am using a Micrologix 1200 L24BXB controller, I know the input can be wired sinking or sourcing but what is the output? Is it sourcing as during active high condition it gives 24V?
Is there a way I can make it sinking?
Thanks for your time
Thanks for you reply. I can see the inputs can be wired sourcing or sinking. But the output looks like its sourcing...
I am using Output 3 which is FET.. so that would be sourcing and cannot be changed.. right?
Yes, thats my read. If you're just looking for one, then you'd want to use the first or second output that has individual commons. Or you could use a simple 24V "icecube" relay and use the relay contact off of it.
I have an application using a MicroLogix 1200 that requires a pneumatic valve to be toggled on/of once per second for 5 minutes each hour. This...
2,717
Hey all! Long time reader, first time poster! I have an EA9-T7CL and an MicroLogix 1200 connected via DF1. I'm all good and got everything mostly...
653
Hi every master,Recently i met a fault about 1762-L40BWA 1,When i get the PLC, The Fault light is lighting, I am not remember the fault message,I...
720
Hello everybody and master,I met a problem about ML1200.It is described as below: 1,When i got this PLC,The FAULT light is lighting, My computer...
1,113
I had planned to use PTO instructions to control a servo motor, single axis only. We have a ML1200 BWA model. According to the ML1200 manual...
3,492
