Is there a standard for idle shut-off time?
technolog
May 2015
Ohio
320
We refurbish various tube benders and end formers. Quite often they have a PLC output which, if the machine is idle with the hydraulic pump running but no motion happening, will switch off after a time and shut down the hydraulic pump. My boss was wondering if there was any sort of standard for what this idle time delay should be. We see various times on different machines, typically in the 2 to 15 minutes range. Does anyone have any insight?
I have done a couple of machines with hydraulics, and I have idle time logic if the cylinders are not moving for 10 minutes, however there is an "off" time cycle for some of the weekend recirc cycle times so I use a .TT bit from the off time timer to energize a pressure dump solenoid that removes all the pressure down to about 100 PSI during the Off time. The customer originally wanted me to start and stop the motor, but I convinced them that was too much wear and cycles on the contactor, this solenoid works well.
I would say that the time delay should be determined by what the normal idle time while running is for the equipment in question. I doubt there's a "one size fits all" value for this function.
After some interesting conversation regarding the safety of emergency stops, I saw some posts talking about the safety standard conversation...
26
893
I have programmed servos from a handful of variety of manufacturers and series. Each time I used a PLC without motion functions. I have not worked...
750
Hello, I'm am engineer for a plastic manufacturer. We swapped out a oem motor with one of equivalent nameplate stats made by marathon on our roll...
496
I am trying to implement a sfift-by-wire on a vehicle and for that I am using a standard servo motor...
328
Had an interesting experience this morning. An old Panelview 600, 2711-K6C5X series B to be precise, comes up as error 32. Unfortunately it...
219
