Issues with Servo Motor Stopping ( Kinetix 5500 )
walterj27
Mar 2024
UK
Hi all, New here and new all round to PLC`s. We have a servo drive that runs a cross travel beam backwards and forwards. I am having trouble with the servo motor stopping. Accelerates and decelerates smoothly when in automatic. When ran in jog however the motor stops dead when the jog button is released and looks like it will be a problem to have it stop dead like this. Also stops dead when the e-stop is pressed or the safety gates are opened mid travel. Is there anything I can do to get the motor to stop gradually in both of these situations or at least with the jog situation.
Any Help will be much appreciated.
Walt
Look for the MAS instruction. It has an option to change Decel. If set to NO, then it uses the Decel of the previous motion command (a MAJ, MAM ,etc). If set to YES, it uses the decel in the MAS. The decel could be units/s^2, %, time, etc so be aware of the units to determine if the value needs to increase or decrease.
As for the EStop, depends on how the estop is being handled. If it is using CIP Safety, depends on the drive...ERS3 or ERS4 type have controlled motion stops SS1. If it's using hardwired STO, then less options.
Has anyone on this site used the Automation Direct Sure Servo software? It is Sure servo Pro. Reason i ask is now the company i have been working...
2,789
I have a machine with 5 AB Ultra3000 servo drive ( 2098-dsd-hv220-se ), with ( I believe ) a AB MPL-680 motor. Came in, first thing in the...
4,061
More of a heads up, warning may be a little strong but probably warrented. Management selected on the recommendation distributor AC Tech 940...
6,760
Well now this is a very odd state of affairs, been start-up testing a machine the last few days with a large amount off servo drives; approximatly...
4,216
I have an Allen Bradley temperature switch that I am trying to use in studio 5000. I am getting the message "Unable to interpret the IODD file"...
79
