Know a compact terminal list divider ?
JesperMP
Feb 2003
ᚴᚬᛒᛅᚾᚼᚬᚠᚾ
16,342
Hi.
I am on the lookout for a terminal list divider (*) that is both compact and yet allows enough space for the label for individual terminal list.
*: I dont know the proper english term for it, but look at the picture and you will know what I mean.
On the attached photo you see what we have at the moment.
Notice how each divider takes up 10 mm. With many small terminal strips after each other, the dividers take up an unpropertional amount of valuable "strip"-space.
What I want is a divider that is 5-6 mm wide, and where you can attach a label that is 5-6 mm wide and 25 mm long.
The terminals are Phoenix Contact, and the current divider is CLIPFIX 35.
There is a more compact CLIPFIX 35-5, but the labels that you can attach to that one are just too flimsy fro my liking. They sort of ride high above the terminal list, and I am afraid they may fall off in the long run.
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
124
What happens if you power up a 1783-MS10T with a Compact Flash card from a 1783-MS06T? Does it work, but with the "extra" ports unconfigured? If...
94
gents, I am trying to configure communication with EMERSON PK300 controller through port A1 using generic ethernet communication module . I could...
134
My PLC is currently running the program and the process is still live. One of my 1769-if16C cards values are all frozen but the card is not...
131
I've blown the Output Transistor on the Output Card of a Compact Logix 1769-L24ER-QBFC1B It says J378. Does anyone know the replacement part...
208
