KNX/DALI gateway
one2go
May 2016
Cakovec
51
Hello everyone,
i know its not related to the plcs, but I hope someone can help.
The problem is KNX / DALI Gateway N 141/03 real time clock. I am using KNX lux sensor, gateway, and light actuators. It was successfully powered on and off by simulating day/night, but the problem is scene change on exact time. As it is said in product manual it has own real time clock, but every time I try to read time in ETS4 it says that the time is 00:00:00. There is no right instruction how to set up clock. I have also tried to write time from ETS4 into gateway but no luck. General and Location settings are also set up properly. Is there anything else i could do. I might missunderstood something. I appreciate your help.
Thanks a lot.
where i can find the following gateways (converters) to link different networks? 1. Ethernet copper to Ethernet fiber optic 2. Ethernet copper...
1,657
Dear friends i urgently need ets3 software, if you have kindly inform me. thank you
1,553
I am looking at doing a DALI (Digital addressable lighting interface project). This will be a pilot project to evaluate the technology. I will be...
1,747
Hi All, Has any of you tried to change the IP Gateway of the PLC (of course, essentially of the ENBT card), while in a redundant configuration...
144
We are trying to poll data coming from a PLC for remote monitoring we have the IP address of the PLC and the default port number and the path is...
25
666
