L32E CompactLogix Controller
runx999
Nov 2005
Port Elizabeth
Hi all
Is it possible to program the L32E controller via the ethernet port. I have setup the network address on the controller and can ping it, but have not been able to establish a connection with RSLinx to program the controller.
Cheers
Hi dmac
Thanks for the link. I can see the ethernet port in RSLinx, but it does not select it as a valid path from the software. Do you perhaps have a link that explains the setup step by step.
If you have all the EDS files correctly installed, RSLinx will show a "+" sign to the left of each network device or segment, so you can "drill down" from the Ethernet port to the virtual backplane to the controller itself.
RSLogix 5000 needs to know the path all the way to the controller, not just to the Ethernet interface. Even though it's physically built into the CompactLogix controller, it is logically a "virtual backplane" device and works similar to a ControlLogix installed in Slot 0.
Thanks Ken
I have downloaded the latest EDS files and will try it when I get onto site again. Thanks for the help guys.
Cheers
AJ
Hello . Info: Panelview plus 400 2711P-K4M20D Compactlogix 1769-l32E i make a program in RSlogix 5000 and Factorytalk view for...
1,820
Hello again. I need to flash a CompactLogix L32E from firmware ver15 to 16. It has several Panelview Plus's Series D Rev A, connected via...
2,802
Hello. I am trying to establish communication between CompactLogix 1769-L32E and CompactLogix 1768-L43 using serial port but with DeviceNet (and...
2,779
Respected sir/madam I have CompactLogix L32E And I want to data log into logic . is any module or card require to it. request you guid me and if...
1,403
A new member of our Forum community, maheshbhaiya, posted this as PMs and a resurrected thread, so I'm going to give it a push in the right...
2,100
