label for wiring
NFPA "Electrical Standard for Industrial Machinery", ANNEX D, illustrates one common method. Each conductor is identified by a unique number, assigned in sequential order, or by using the drawing's line reference. When using the line reference system, each conductor on a particular line is identified, XXXXA, XXXXB, XXXXC, etc.
Standard in the electrical power category is 5 or 6 digits. For example:
Wire # PPPLLW
PPP= Page of the drawing
LL = Line of the drawing
W = wire #, counted from left to right
As for me, I make up my own method depending on the complexity of the job. If it has less than 50 wires, I start with Wire #1 and add 1 until finished.
Our standard is to make sure every wire has a unique label. Doesn't matter so much what the label is, just that it is accurate and unique.
Some folks put the equipment identifier on the wire, such as LT001 for a control loop or 19P002 for a motor on a punp in Unit 19.
A more generic way is to label the wire with its destination or point of termination, such as TB2/12 for the 12th terminal in TB2 block or terminals.
I find the 'destination' one a bit confusing to be honest and prefer the point of termination way. That way you can reference it to a drawing.
We are considering dropping our UL membership because most of our customers do not care if we are a 508A shop. However, there may be times when a...
399
I copied a panel in factory talk HMI for an identical system. The label names are still the same as the original panel but I am trying to change...
142
Hello, My company has recently been tasked with a redesign of an HMI and they were originally using Numeric Inputs to display the values. I am...
967
Hi Guys I'm having trouble assigning a tag to an activex label on a Multipage Tab. I can assign the tag to an active x label on a normal display...
602
Hi there! I'm new to GX Works3 so please bear with me. So far I've created a new project with an FX5U PLC and tried to add some global labels...
1,184
