LAN wifi question
neilm
Feb 2019
Jackman
28
Hello everyone,
I am an Automation Engineer in a manufacturing facility. There are multiple LANs here. I am interested in knowing whether it is possible to use a single router as an access point to multiple networks (since the router has multiple orange ethernet ports).
Regards,
NeilM
You will have to contact the IS/IT department for that answer or the one who programmed your switches.
It all depends on how your network is programmed, what the rules are, brand of switches, and what you are trying to do.
james
Okay, here the switches used are unprogrammed, plug-and-play fashioned. The computers connected to it though have a specific Default gateway. So the question is, can one router have multiple default gateways?
That's kinda like asking "will my car go over 100 mph without going into overdrive?" There are a lot of variables that would need to be answered before answering that question. However, there are WiFi Access Points that can be configured to act a multiple Access Points to multiple different WiFi networks.
Having said all of that, you're asking a simple question that doesn't have a simple answer. Yes it's possible, whether or not you have equipment that will support it or not, only your IT department can answer.
[C]an one router have multiple default gateways?
Short answer: No.
You can make routing tables, but it is not straight forward and it is even possible to do what you are asking with a inexpensive wireless router. You will need expensive managed switches to do what you want, and it is not a simple task for the layman.
Hi all, What is everybody using for getting access to remote machines PLC/HMI local network for snagging and debugging from their desk ? We...
21
9,868
Recently the Broadcom Netxtreme 57xx Gb Controller became defective in my Dell E630 Windows XP, running S7 TIA Portal V11. So, I couldn't go...
4,379
On all pages of my project i have a lot of information, texts and details that should not not be shown. I can remove them for each part apart from...
42
Good morning colleagues, Does anyone know the cost of an EPLAN license and where I can buy it from an official distributor?
194
Hi All, Have a question about setting up routing across VLANS. I have attached a picture of the layout and will try describe best I can...
711
