lenze drive blues
hotrod
Aug 2005
ohio
48
Well here goes, I have aboult 8 lenze drives running motors and other things, problem is, I just had one blow fire out of the top of one, replaced it, checked the wiring, motors, you name it,then the drive for a different motor blows a cover off the bottom of the drive that is for the leads going to the motor. how do you get a short in the output of a drive if it's not being sent an input to run?, I'm still wet behind the ears, but learning.
Well, wet behind the ears you may be but stuff happens and if anything can happen or go wrong, it will! With that said! You will get better response to your post if you put it in the main discussion forum, and not here in the practice section. A little more info would be helpful on your exact failure mode and I am sure there are some experts here that will offer some suggestions on what may have happened! Good luck! Welcome to the forum too!
ok, but how would a drive enable itself?, all i did was power up the panel and reset the e-stop circuit, and BOOOM.,
Kindly, has anyone tried to control Lenze servomotors with Siemens S120 drives ? Any special hints ? Have some concerns for the resolver and servo...
249
Hello everyone, One of our machine we use Siemens Cpu315-2dp. And this cpu communicate with 4 Lenze servo drives series 9300 via profibus. Also...
198
I have an issue after programming a Lenze 8200 Vector drive using Lenze Global DRive Easy software. I have connected using a Can Bus interface...
605
Hello, I am trying to get a 32MV4341 Lenze AC Tech VFD running a conveyor to be controlled by a 24VDC photo eye on the nose end of the conveyor...
1,955
Hi all, I now need to wrestle with a Lenze Servo Drive 93xx and the PLC within it. I have Global Drive Control & Global Drive PLC Developer...
2,426
