Ligar um compaclogix 5000 e slc 500 pela porta serial
rorisvon
Dec 2016
manaus
Good afternoon!
I would like to know if there is anyone in the group who could help me !!!! Next I have a compaclogix 5000 with two serial ports using adf1 protocol, I have another 1200 micrologix with a serial port using adf1 protocol, I connected the slc 500 through the serial port of 5000 and I can access the plc using the same cable ... I wanted to configure them to Exchange messages !!! I already researched I found a lot using modem, but I want to do the test using only the plcs !!! If you have someone who can help thanks ...
Boa tarde!
Queria saber se tem alguém no grupo que poderia me ajudar!!!! Seguinte Tenho um compaclogix 5000 com duas portas seriais usando protocolo adf1, tenho outro micrologix 1200 com uma porta serial usando protocolo adf1, conectei o slc 500 pela porta serial do 5000 consigo fazer acessar o plc usando o mesmo cabo... Queria configurar eles pra trocarem mensagens!!! Já pesquisei encontrei muita coisa usando modem, só que quero fazer o teste usando somente os plcs!!! Se tiver alguém que possa ajudar agradeço...
Acho que se escreveres em Ingles teras um pouco mais de ajuda... particularmente neste forum.
Infelizmente eu so me dou com Siemens.
Se precisares de ajuda com a traducao, avisa e eu traduzo.
"Connecting a compaclogix 5000 and slc 500 to the serial port
Good afternoon!
I would like to know if there is anyone in the group who could help me !!!! Next I have a compaclogix 5000 with two serial ports using adf1 protocol, I have another 1200 micrologix with a serial port using adf1 protocol, I connected the slc 500 through the serial port of 5000 and I can access the plc using the same cable ... I wanted to configure them to Exchange messages !!! I already researched I found a lot using modem, but I want to do the test using only the plcs !!! If you have someone who can help thanks ..."
http://www.plctalk.net/qanda/showthread.php?t=66877
The above thread may help you out.
Regards,
I am a beginner on the AB platform and I have a question. I have a 1769-l32e with scanner devicenet,I am presented with the offer to buy a point...
1,743
Hi!. I have CompaqLogix 5069-L330ER project that I want to simulate with the Studio5000 Emulate. I usually create a copy of my project...
920
Hi, I have a Compaclogix L33ER that from time to time loose the program. I haven't been able to find why is doing it. I am trying to make the...
1,428
CompactLogix L33ER with Panel View 7 system originally running v28 was working fine in the field. Updated the PLC software and firmware to v30 to...
1,918
My Wall Clock , on a CompactLogix ,as been working great , until now. My Year , Month , Day , Minute , Second , and Microsecond is good , but my...
1,884
